Sea Doo and trailer. Approx 1300 lbs. Tow in 3rd?
c good
I know everyone recommends towing in 3 rd for trailers in general. I recently purchased an older Seadoo and trailer. Combined Weight is at most 1300 lbs.
I have a PCM of N. Carolina auxiliary transmission cooler installed. Fresh transmission fluid.
Can I tow in Drive? Or do I have to keep it in 3rd? Thanks for any info.
I guess it would depend on the terrain and gearing. If you have the GU6 gearing, I would tow in 3rd.
If you are noticing the transmission shifting more than it would normally, put it in 3rd.
I'd try it in D and see how it acts. Probably will still need to downshift to 3rd going up grades or you notice it hunting between 3rd and 4th. Headwinds can also affect towing.
backyarder
