02 keyless entry questions
mo_86_05
My keyless entry is acting strange. When walking to the side of my truck, i have to be almost all the way on it for it to work right. If im approaching it from the front, then it works from a further distance. What can i do to make it work from a greater distance?
My best recommendation is to change the battery in the remote FOB. Should only cost a few bucks to give it a shot.
Battery type: CR2032
Insert a quarter (not a knife) into the side of the unit to pry it apart.
Battery type might be different depending on your truck. If you fill in you profile it will help everyone :thumbsup:
:iagree: But if that doesn't work, your Lift Gate Module may be failing or you have the classic frayed wiring...it controls the remote lock/unlock.
