04 Envoy data link
Jul 13, 2026
3
FL
Replaced the door accuator on passenger side anad when I reconnected batt I lost IP lights except Batt and CheckEngine. Research pointed to Class 2 Data linkks, and located an 11 pin comb connector (under left dash). Unplugging the comb restored the IP lights. Looking for a wiring diagram that show this connector to trace wires.
Find a post from @Mooseman - His signature has download links for the service manual. Should be able to help.
To me, it sounds like the door actuator you installed is internally faulted to ground.
Hi and welcome.
Do you mean you replaced the passenger side door switch module? Have you tried just disconnecting that to see if it restores the lights? When you pull the comb and the lights work, this tells me something on the network is pulling down the network. If it's not the door module, then you would need to chase down which module.
Manuals with schematics are available here:
However all manuals for all vehicles which are a little better for searching are available here:
Hi and welcome.
Sorry for detail ommission, I replaced the HVAC blend door acctuator, and even with it disconnected the problem persists. I've checked several of the manual links you provided (thank you) but can't find a wiring connection diagram to the comb connector that I have seen identified as both JX200, and also Splice Pack 205.
The bad news is that the "great link" that mooseman provided DOES NOT appear to have indexing for some of the elements in the manual. In this case, the SP205 is "referenced" in the tables for splices.... near the bottom. I haven't found the jx200 identifier. I am still looking to see the where the sp205 is described. I will see what the GM SM has.
ADDED: I found the splice pack 205... search on "information bus" and you should find a diagram of the area showing the connections involved.
TexTJ209
