Street
Hi Everyone,
My first post to the forum and it's a whopper.
First, background info:
My dad acquired the Envoy (lets call her Goldilocks - cause she's a picky b*tch) for me about a year and a half ago. Goldi has 156k miles on her today. She's had a rebuilt transmission (jasper), the motor has been gone over, compression it great, and my last tank of fuel ran 17MPG. She has a bit of an odd assortment of options. The typical SLE, but add On-Star, auto-headlights, dimming mirror w/temp&compass. I'm still stumped as how the auto-headlights are supposed to work, the headlight switch is just a three position (off-park-headlights). But that one I'll save for another day.
Here is the main malfunction: At any given startup the TCCM might not wake up (no light on 4wd switch, and Service 4wd on dash); sometimes powering down and restarting "cures" it, but sometimes not. But always will comeback after few ignition cycles. But wait, not the real annoying issue.
The real one comes up as follows:
I'm cruising on the freeway, cruise on 70, window open. I decide I've had enough of the buffeting, and I'll run the A/C. Reach down and turn (manual hvac) fan from off to 3; cruise dies, and I'm coasting. First time it did this I thought I blew a fuse and was going to end up on the side of the road, then after laughing at myself for a moment, realizing the motor is still running, put my foot back on throttle, and keep moving. What I realize then is that my dash is alight! ABS, Brake, and Service4wd are all on, and no HVAC to boot; the A/C compressor is cycling, indicator is lit on a/c button, but the blower motor has no power. Turning fan on/off makes no changes; except off, turns off a/c button and compressor stops engaging.
So, I check the fuses - none are blown. And to boot, a restart and voila, HVAC fan is on and ABS/Brake MILs are off. Service4wd is still on, but I'm used that and sure enough an ignition cycle later, that's off too.
Thus, I figure I have a ground issue. I spent last Saturday with cleaning every ground point (though, they all visually appeared clean). I hit the contact surfaces with a scuff pad and got pretty shiny metal on the mating surfaces - both in the body and under the hood/frame. (I work from home, so I don't drive everyday, so she sits for 24,48,72 hrs at a time). So I'm out Friday, and Goldilocks gets me again. This time on startup, a few moments after engine is running, ABS, Brake, and Srv4wd all appear. Indicator on 4wd selector switch is lit (usually when the module doesn't wake up, no indicator lights on the switch). Cruise worked, but not the blower fan.
One last thing, I have an ongoing issue with parasitic battery drain with the factory passenger side door module. I've been through 2 replacements that work for a period of time (say a month or two) then just refuse to work (no window, no lock, no mirror.), but don't drain the battery. BUT, reinstalling the factory module gets my window and locks in the door working and it might even been good for a day or two before the drain starts again. At which point, I just unplug the connectors from the module and call it good for now -- which is the state it is in when the above happens, disconnected.
So if anyone has experience resolving these issues, please let me know. I'm at wits end with Goldilocks' issues, but I really need her to be good for another year.
