Build thread time
2010 CamaroSS
Now that I'm pretty confident I'll be keeping this Trailblazer, unlike the other one, time to start with the build thread.
First, the generic dealer pics when I got the truck:
Now as you can see in this picture, there is already an aftermarket exhaust on it. Still trying to figure out which brand:
First mod I did was the Supermod engine upgrade!!!
Supersparkz
Ported Throttle body
HP tune
The tail light circuit board on the driver side went out so I had to replace it. I ended up ordering a pair. In doing so, I changed the reverse lights to CREE LED reverse lights:
Next, item was the replacing the damaged power mirror switch. All fixed!!!
The 3rd brake light ended up going on me, so why replace when you can mod:
However, due to some nicely hidden details by the dealer, unfortunately I have already had to replace the Cam actuator solenoid, cam position sensor, transmission, and transmission cooler lines.
I know the next item to be replaced are the back hatch window hydrolic struts (I know this because the window kept falling on me when I tried to change the 3rd brake light this morning till I jammed it open with something)
