Dead 4.2 swap to 6.0
My next TB will get efans, I already have a set of fans I'm going to use. Never bothered on my 02 for a few reasons but the next will get all the stuff that I never got to or didn't want to mess with previously. Should be good.
What fans are you thinking of using? I got Venture fans like Mooseman did for his. It'll take some fabbing to make the shroud work properly but that shouldn't be a problem. I think dual fans will work better than a single E fan since more area of the radiator will be covered, and should be quieter for the same airflow.
Reactions: Decembersend
Somebody had found an aluminum radiator from a Dodge something on eBay that had the same dimensions and water outlets but for the I6.
I picked up a set of late model Uplander/ Montana SV6 fans. They would have less modding to do and seem to pull even more air. I never got a chance to install them since i reverted my old TB back to stock with an '08 clutch. I might do the Saab but don't know it it's worth the hassle. The efan koolaid has lost its punch.
Glad to hear you found another engine brother [emoji41]
I'm researching now on what fans to get, so I'm not sure yet but I will let everyone know what I decide.
Thanks
kjkim93 said:
Before you put the ls2 in don't forget to do the oil pick up tube! Might as well! Looking forward to this swap.
Yep :yes: that's definitely on my to do list.
I also found a sweet radiator and SPL fan setup. FSR radiator I found on TBSS, plus I can get a built in Transcooler :cool: .
Did a little bit of work today, Removed both CV axles. I just want to make sure the info I found is correct the SS and standard TB use the same front CV axles?
Upon removal I checked my upper ball joints which I already knew were bad and as you can see they are.
Driver side axle removed (I didn't take pictures of the passengers side but they look the same)
Borrowed the idea from Roadie to cover the holes on the disconnect
Used tape as a precaution
P.S. I know, I know the rust is bad, I'm going to have to sand it down and hit it with rustoleum.
I'm surprised to see actual rust in a Florida vehicle. Here we would call that "factory fresh" :smile: Mike.
northcreek said:
I'm surprised to see actual rust in a Florida vehicle. Here we would call that "factory fresh" [emoji2] Mike.
I thought the same thing but then you gotta think about the sea breeze. I've heard something about cars rusting if you live next to the ocean.
She's far from a Florida Vechicle, she spent 7years in Snowy Ohio and 6 of those were without me. She would be a lot cleaner if I had her from the get go. I took it to the car wash (heated water) during the winter to have the underbody cleaned often but the damage was done.
A little bit more work done today. Removed Alternator, PCM, Throttle body and disconnected the left side wire harness.
When is the "boat anchor" comming out? :biggrin:
Soon I'm taken time every night to get it ready. I'm still waiting for a tracking number for my new engine. Maybe this weekend I'll have it out only time will tell
Good news my engine will be here tomorrow. Unfortunately it won't be ready to install quite yet but at least I'll have it in my possession.
Oh and some other good news is my Hood will be here tomorrow too.
What kinda hood did you get man?
Oh I've seen that before. So you gonna have to cut put those opening yourself huh?
Reactions: TollKeeper
That's what I was worried about to, but when I called they told me they come precut with grills, so I will find out tomorrow for sure.
Ohh okay, well hopefully that really is the case
The other 2 members in this area who got that hood said all they had to do when they got it, was get it painted and mounted. So I'd be surprised if his hood showed up incomplete.
I forgot to post this on Saturday.
I took my old rear diff off and sold it to Triz. and she now sits on four 4T jackstands. My new one came yesterday so I'm prob. going to install it tonight.
Reactions: triz and Blckshdw
I like that hood!
I just took my diff off tonight. It's sitting on the lift till the am. Thanks a lot by the way.
Here's what I did today.
I wanted to sand down and paint the rear differential before I put it on the truck. I initially bought some wire brushes for my drill and I wasn't getting the results I wanted. So I did some research on sand blasting and found that HF carries a responsibly priced sand blasting kit. I'm quite surprised on the result it's defiantly not finished, my air compressor can't keep up with it and it's a little disappointing but it is what it is.
Here's the pics.
Reactions: Blckshdw and Mounce
Here's the pics.
I was looking at one of those sand blasting kits the other day, I think harbor freight has one for about $150. are you disappointed in the kit or the compressor? I am wanting to get one also
The Kit I bought from HF was $39. I paired it with my craftman compressor. It's a 12 Gallon 1HP compressor and sand blasting takes a lot of air and my compressor can't keep up.
So to answer your question it my compressor I disappointed in the sandblasting kit is great
Reactions: BlazingTrails
Well I tried to put the rear differential on yesterday but my Brother and I couldn't move it lol. The old differential was heavy but man this new one is crazy heavy. I'm bringing home one of our high lift jacks we use for ACs so I can pull it to the TB. :biggrin:
Here is Saturdays activity.
This is the High Lift I used to move the differential off the trailer to the TB, it made it easier that for sure. Only problem I had was the 100lbs of sand laying on the ground that I used to sand blast.
I went and picked up these hand truck from HF and they made it extremely easy to get the differential in the correct place.
Before I put on the Wheels I decided to repaint my calipers from red to silver to match my Fox 2.0 Shocks. The caliper were left hanging my coat hangers after I was done painting them.
Heres a night shot of the new differential
Not much on Sunday except for putting a second coat of paint on.
Caliper all painted and bolted on
A look of the caliper though the wheel. The wheels were sitting in the dirt in the backyard that's why they're so filthy.
Nice work, what did you use to paint the caliper's? Also when you remove the engine please take some pics a engine removal article is much needed.
This weekend I'm going to attempt to remove the engine. I bought a 2T engine hoist from HF last week, I still haven't put it together yet.
I'm going to have my a few people helping me out remove it. If anyone wants to have a mini meet your more then welcome to come over. Carlton, Jimmy?
What time are you starting? I've got evening plans, and some tentative day plans, but if things fall through, I might try and swing down. Jimmy has been spending all his free time working on the new house, so everything will be ready before the baby arrives.
Edit: I can probably drag Carlos down with me, and maybe get Angel if he isn't tied up.
kaypenner0222
