Engine Light P0014
Yacdogg
Hello, I have a 06' Trailblazer I6, and yesterday the engine light came on, and I checked it with torque pro and it says "P0014 - Powertrain "B" Camshaft Position - Timing Over - Andvanced or System Performance (Bank 1)" ...... what does it mean ? is it ok to drive alittle bit with it on ? (let wife drive it the whole mile she drives to work) until I can get it fixed
That is more of a performance issue rather then a trouble code. You can drive it but it is running advanced. Have you done a google search? It yields multiple hits on the old site that could really help you out.
I currently have a pcm4less pcm in the TB, if I take it out and put my original, i can send pcm4less my pcm to reprogram to fix the problem
So you have a Core PCM from them? And then this issue started?
longbeard14
