I have a 2006 TB LS, with power side mirrors, without turn signal and not heated. would these New Right Side Mirror Chevrolet Trailblazer 2002 2007 | eBay be plug and play ?
the roadie said:They are plug and play. Heaters come on with the rear window defogger switch.
Rs8892 said:Do all power mirrors have heat? I should have looked a little longer a few months ago when I bought the amber turn signals covers, would have been cheaper and easier to just swap them out. :headbash:
Mark20 said:For the longest time I thought my 2005 Envoy did not have heated mirrors. Last winter much to my surprise after 7 years of ownership I noticed the frost on the mirrors melting while the rear defrost was on. Turns out they were standard but don't have the heated mirror symbol. Don't know if they were dropped from 2006 models.
Darkrider_LS said:If i recall correctly from an earlier topic the wiring for both the heat and the turn signals is in the doors just not used with the non heat/turnsignal mirrors right?
the roadie said:That's correct. GM threw us a bone with the turn signal support as well. Plus cruise control, which activates simply with a new stalk.
Sparky said:Correct. It was probably cheaper for GM to use the same wiring harness on all the models and just change the mirrors than to have multiple wiring harnesses for all the different option packages. Which is also why the fuse box comes preloaded with every fuse for every option, regardless of whether you have the options or not. Means you may have a few extra spares![]()
Sparky said:I don't think mine have the symbol either, but the previous owner put wide angle spot mirrors towards the outside of the mirror so if mine did have a symbol it would be hidden I suppose.
kickass audio said:I have my drivers side mirror with the symbol on it and my passenger doesn't have it
kickass audio said:What you can do to test if your car can support heated mirrors is to hit the rear defrost button and listen for a click in your doors.
