LED Mod Thread
Found a 3M one in the auto lighting section. Was way cheaper than both of these. Got solder w/ it, for a total cost of like $8 :biggrin: Now to start practicing on some random thing i've found at work a while ago. Should be good to practice on
[sharedmedia=core:attachments:59011]
Reactions: RayGumm and Mounce
Okay so I'm a noob when it comes to soldering LEDs, that's the only thing I've never done with them. So I did a quick little experiment to see if I understand how this all is supposed to work. The longer lead is positive, the shorter lead is negative. The resistor is attached to the positive lead. Voila! This stuff is waaaay easier than expected. Excuse the crudeness of this experiment. uploadfromtaptalk1411855979000.jpg
Thanks man, that's one of my favorite mods, and probably gets more compliments than any of the other interior LED mods I've done.
:undecided: Who knows, you might go home at the end of next month with that mod done to your truck. :cool:
No problem at all man, very impressed with your LED mod prowess.
I wouldn't want to steal your mod though man :blinkhuh:
RayGumm said:
Stupid noob question time!!!
I have a set of Xenon HID 9006 headlights courtesy of Mr. DManns67, but my hi-beams are stock. I also have the quad hi mod - courtesy of MAY03LT, so when I kick my brights on it looks goofy as the hi-beams are a sickly pale yellow compared to the HID's. been wanting to replace the hi-beam bulbs with CREE LED's, so can I just buy some 9005 Cree LED's and slap'em in? These are what I was thinking of getting.. Yes? No? HELP!!
Thanks Y'all! :thumbsup:
Do it man. I have been wanting to see some 9005 Crees in person. I have been contemplating going with them as well.
Reactions: djthumper
Technically, it's not my mod, I saw it done by other members on the OS years ago. Just don't think anybody else has done it in the last 5 years. Besides, if I didn't want other people to have it, I wouldn't post it. Of course, you can take the mod, make it your own, and change it. Use different colors, put them in a pattern, or whatever you can come up with. The possibilities are only limited by your imagination (and budget)
Ohh okay; if I did, i'd probably do a different pattern then :biggrin:
:thumbsup: Only thing to be careful with, is account for the mounting clips underneath when making your template. Other than that, it's really a simple mod to do.
I wired mine to the dome lights, I know others have talked about going to the individual door switches. For me, I don't have a problem with them being on when the door is closed. Visually, it's the same thing, but don't have to worry about fishing wires through the door jambs.
I'm not sure how i'd go about it, usually my methods are odd compared to others when it comes to wiring LEDs up
The 2 ways I would recommend, is to either make a paper template, or lay down some painters/masking tape, and draw your pattern on that, then drill your holes. That way you can make changes and adjustments as needed before you start drilling. Wiring them up afterwards is usually the easy part. Figuring out where to put them to get the look your after is the hard part.
Sounds good :thumbsup:
I'm working on the rear hvac controls at the moment. I'm just puzzled on the polarity of the 2 larger LEDs, and then the small one that indicates power
Well, you should have a multimeter, that you can check polarities with. The simpler option, and one I used to use, was solder a resistor to an LED, and use that as your polarity tester. Much smaller, you can stick it in a pocket, or behind your ear when you don't need it right away.
I supposedly have a very expensive one according to Brandon, that I "acquired" from work
It'll be put to good use buddy :thumbsup:
Ok, on the rear door window switches, they dont have normal bulbs, they have these little led, can you replace those with a standard led, or am I kinda stuck with those?
Yeah you can use a standard LED, I did
I don't recall any green rubber
Reactions: BHAMER
BHAMER said:
I,m assuming that you just unsolder the little one and solder in the new one, then trim the green rubber around it?
Yep, that's what I did with mine
Finally got to the headlight switch & rear wiper switch. Green LEDs in both, rear wiper does have one Blue LED in the middle though:
[sharedmedia=core:attachments:59921]
[sharedmedia=core:attachments:59926]
[sharedmedia=core:attachments:59924]
[sharedmedia=core:attachments:59925]
[sharedmedia=core:attachments:59923]
[sharedmedia=core:attachments:59922]
And now that my mod bug has realized that I have figured out a decent financial plan for future repairs and mods it has been rattling it's cage constantly whenever it sees other mod bugs getting work done :rotfl:
Been a while since anyone has been in here so here's what I did out of boredom today I made a board of purple leds
Gonna be bright like my interior lol :rotfl:
Same here. My 5630 chips are crazy bright.
Same boat, can't see shit outside when my lights are on inside
Aarkon said:
It was gonna be the start to my dome lights but they just aren't bright enough for me
Yeah, you've got WAY too much unused space on those boards, especially since you put the resistors on the backside. If you did add more LEDs to the board, I'd encourage you to wire them up in an array of some sort for higher efficiency, and less heat from having so many resistors. :twocents:
You will have a spaceship lighted interior like Carlton.
Who doesn't like spaceships?
Most likely when I go led in the domes of my trucks I will probably just go with pre-built boards...no way in hell do I have the concentration and patience to tackle assembling something like that!....on the flipside if any of you guys who have built theirs in here are willing to make a spare set in the near future I will gladly be interested in making a deal of some sort.
I have a burnt out bulb in my passenger's side window button. Naturally this means the entire interior is now due for an LED upgrade.
I have found some useful info around the forums, but no dedicated thread or write up for doing the buttons in LED.
Is there a thread for it where I could find some more detailed info?
Nothing wrong with that.
I bought cheap Chinese T10s and 212-2 and they're still so much brighter than the stock bulbs.
There's no dedicated write up, because there are a few different ways to do it. Some people are happy with 1 LED in stock locations, others wanted 1 LED per button. A couple of not-so-noobs have asked me for pointers, but have gone in slightly different directions when they did their door modules. Their pics are posted in this thread somewhere, just have to find em.
Timmy22
