Need help identifying leak
xOgrex
Got a pretty major leak from one of the hard lines running above the left front strut tower near the battery. Pretty sure its either an oil or trans cooler line as it appears to connect to the radiator but I can't see where the other end goes and I can't get under the vehicle. I've included a picture showing the line it appears to be coming from. Any help would be appreciated.
I suggest checking all the fluids. Easier than getting under the vehicle. If you notice some on the ground, either the trans fluid or ps steering fluid would be low. Check the fluid daily to prevent catastrophic failure until repaired.
Thanks guys. I tried checking the fluids but nothing seemed low. Trucks been sitting a while and noticed it after driving for a bit over the weekend.
