DodgeTransmissionsGoBoom
I jacked up one of the electrical connectors on the pcm the grey plug after cleaning them with qd cleaner. The cleaner caused the gasket to swell too large to fit and when I went to install the plug after drying it slid in half way and made a very disturbing pop instead of the satisfying click. Pulled it back out and found all four round nubs had broken off on the pcm fml... I boiled the gasket to shrink it back down and put a super thin coat of grease on it and it slid in all the way and is holding strong but doesn't have anything locking it down. I can get a junkyard pcm near me for about 45 bucks but I'm not sure if my scanner will rewrite the vin number. I've programmed keys for a salvage ford with no other known keys in the past with success. But I'm not sure if gm requires the entire software to be reflashed for a vin to be changed. It's a 2008 tb 4.2l. the scanner I have is an x431v+ costs about $1200. Not sure if it's expensive enough to do the job it has basically done everything else I've thrown at it though I just don't want to risk buying a pcm and finding out I can't do it. I feel sure someone has tried this before.
Here's the scanner I have
