Hi there, my 2002 envoy has been broken down for six months, been driving around in a minivan because of lack of time to fix and small shops won't touch it dealership wants to charge me thousands, hoping someone has had this issue or knows how to fix it.
Here it goes:
ripped the engine down three times, first cause was engine vibration, was told simple fix replace the harmonic balancer. Did this took about half a day no problems, tightened everything to torque and dod the extra 180, went to start envoy vibration gone but now oil is misting out of the balancer, come to find out we have to replace a crankshaft seal, took balancer back off pulled out old seal, which was nasty, new seal in put everything back together, misting still there, double checked to make sure everything is tight, put back together, engine started no misting or vibrations life is good, put everything away hooked envoy up to battery charger to charge over night because the envoy had been sitting for 3 months at this point battery was dead. Next day fired the truck up ran about 30 seconds and oils start pouring out of the balancer!!! Not misting pouring Put back in garage took everything apart again, but this time what was left of a rubber seal, the size of the crankshaft bolt came out with it...is this from the crankshaft? Are there two seals? At this point we ran out of time and it's been sitting there, starting to get some free time and would love to drive this for the summer, someone please help, at a loss at this point, can't even find a crankshaft to buy for this thing. The main question is... What is causing oil to come out fom behind the balancer as a result of pulling the crankshaft bolt?
Thanks for youre time
Here it goes:
Of course the service tech's at dealership are saying anywhere from 500 to 2000 dollars. too big of a range for us.
