Emcee
- Joined
- Mar 14, 2015
- Posts
- 15
(That should say "replaced" in the title.)
I replaced the bags fine, following Arnott's instructions and some threads here. I know the compressor is still working, as it turns on when I press the inflator button inside the rear hatch. How can I trigger it to go off? Is there a trick? I've got it lifted off the ground by the rear axel right now.
Thanks!
EDIT: I should mention I did not unplug the battery, but I did remove the #1 and #15 fuses (which I have re-inserted).
Thanks!
