Retained Accessory Power
Black LT
I was wanting Retained Accessory Power (RAP) for my radio.
Thanks to Pittfan from a post on the other site, I was able to locate a rap wire.
There's 2 blue wires in the smaller bundle of wires coming out of the rear of the rear fuse box. I'm not sure if there's a way to differentiate, but I had a 50/50 shot and got the right one.
I wired in a relay - (87)power from the power wire feeding the fuse box, (85)ground from fuse box mounting stud, (86) rap wire, (30) to the radio.
One mistake in the pics, I didn't have a fuse in the power wire(87) - one was added.
And that's as far as I am - not hooked up yet.
Reactions: Mobileterminaluser
Did you cover that soldering connection? I assume you did before it got shoved under the carpet.
Ha, yeah - I just left it that way for the pic so as to show how I tapped in.
Oh, and I have it hooked up and the radio works with RAP now.
The blue wire goes to where? I'm not good at stereo anything. just turning on pushing play. looking to buy the walmart double din stereo from Dual XDVD256BT. i want to keep the chimes/warnings. dont need the xm on/off with ignition & when door opens it shuts off.
Ill take some pics of the voy wires
weilandtr
