The Friendly Face of Linux
Desktop works with 64-bit Ubuntu. I'll put the 64-bit Mint ISO on a stick and try it again to see what happens.
For those of us interested in the PICO-Scope Pro Grade Oscilloscopes who prefer running their Automotive Diagnostics on the Linux Mint 20+ Operating System Platform... The Folks over at PICO have created a FREE Beta Version 7.0 that installs via Command Line (Terminal) of their latest PICO Professional Automotive Suite, native to the Linux Kernel.
I followed these steps (Coded in Green Text) and successfully installed this PICO Pro SW Suite in Very Short Order using this Linked Site. It runs as flawlessly as the Windows 10 API Version. The Ubuntu 18 LTS flavor is the one that worked best over choosing the Ubuntu 20 OS (Debian Based) for an easy, trouble free installation:
THIS was a Very Pleasant Surprise... RIGHT UP UNTIL I FIGURED OUT THAT IT WOULD NOT WORK WITH MY PICO-SCOPE MODEL# 2204A UNIT… BUT DO NOT DESPAIR, AS I’M STILL ONE PRETTY DAMNED SMART OLD DUDE… SO READ ON, PLEASE ...FOR THE WORK-AROUND :>)
In order for the PICO-Scope Model # 2204A (2) Channel Oscilloscope to be able to use this software ordinarily meant for the PICO 4 Channel Variants... on the "Normal" Windows 7-10 Operating Systems, it will be necessary to Delete the File called "OEM.DLL". Here is How to Do That:
However… for Linux Mint Users… You will be VERY Happy To Know that I just figured out How to Get the PICO-Scope Model# 2204A to Work Properly on the Latest Linux Mint version of the PICO-Scope Beta 7 Software. Just follow my lead here in this Fairly Technical Step By Step:
Part One:
Visit THIS Link and go to the Bottom of the Page to Download the UBUNTU Version 18.4 LTS Selection:
https://oem.picoauto.com/p7beta/download
Follow THESE Instructions. Open a Terminal in Linux Mint and Copy-Paste these Commands exactly as you see them separated and listed below… One at a Time. After using the ‘sudo’ command… type in your Linux Mint OS “Super-User” System Password if you’re requested to do so:
sudo apt install gnupg ca-certificates
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo "deb https://download.mono-project.com/repo/ubuntu stable-bionic main" | sudo tee /etc/apt/sources.list.d/mono-official-stable.list
Import the public key (only this wget command only once, no need to repeat it):
wget -O - https://labs.picotech.com/Release.gpg.key | sudo apt-key add -
Configure your system repository:
sudo bash -c 'echo "deb https://labs.picotech.com/rc/picoscope7auto/debian/ picoscope main" >/etc/apt/sources.list.d/picoscope7.list'
Update the package manager cache:
sudo apt-get update
Now… Install PicoScope:
sudo apt-get install picoscope
And finally for this part… Update ALL Linux Mint Installation Apps:
sudo apt-get update
Part Two
Open up a Linux Mint Terminal and at the Command Prompt, Key In:
cd /opt/picoscope/include/libps2000
Then, from within that /opt/picoscope/include/libps2000 Sub-Directory, Key In:
ls
You should see one single file listed therein called:
ps2000.h
Next, you must install and run the Linux Mint GEDIT Basic Notepad APP as follows:
sudo apt-get install gedit
Then, Key in the following commands:
sudo gedit /opt/picoscope/include/libps2000/ps2000.h
As soon as the Text Editor displays the contents and programming of the ‘ps2000.h’ File, you MUST search for ANY expressions that are preceded by the Pound Sign “#” and DELETE just that Entry… WITHOUT CHANGING THE POSITION OF ANY OTHER WORDS, NUMBERS OR CHARACTERS WHILE WORKING ON EACH LINE AND ALSO WITHOUT ADDING ANY OTHER INFORMATION.
I have copied and saved a Microsoft Word Document called “PA2000H.DOC” that you can use to check with and compare to the On Screen Terminal after you have finished Editing that Original File. Be Very Patient and Very Careful as you make every single Deletion of all of those “#” Characters. When you have successfully checked and edited all of the lines between Line 1 through Line 607 then press the “Save” Button on the Upper Right Hand Area of the GEDIT Text Editor Border and then X (Exit) out of this application.
Reboot the Computer and install your PICO-Scope Model # 2204A via the USB Cable into the Powered USB Port on your Laptop. Open a Terminal again and at the Command Prompt… Key in:
picoscope
After the PICO-Scope Application starts to run… watch in the center of the screen as the APP begins to finally recognize your PICO-Scope Model # 2204A for the Very First Time. Proceed on from there with other instructions for using the Scope for various types of Automotive Diagnostics with this High End APP..
Reactions: christo829
Within days of installing the PICO-Scope Beta Version 7 Automotive Suite Program... my 'set for manual installation' Synaptic Package Manager alerted me on screen to a whole new raft of updated Hardware Headers for all of the variants for each PICO Model awaiting installation. These started with the Pro Versions that cost around $15,000.00 for The Big Boys and ended with the PICO-Scope Model #2204 as the affordable version in question.
I suspected that if I accepted the Updates and allowed them to install that the New PICO Beta 7 profiles would all be over-written and I'd be right back to Square One with an Original ps2000.h file. Thus, I'd have to go back through the same routine I described in detail in Post# 42 to rectify that file and allow the Updated Application Suite to work on my Model #2204A.
Yup... Sure enough...when viewing the "New" ps2000.h in GEDIT, all of the '#' signs excluding recognition and header functionality were right back on each relevant lines between Line #1 through Line #607.
Now you might think that making and saving a copy of the Modified ps2000.h file to swap in AFTER performing these irregular Application Updates would be the way to go... and I had done so by saving said copy in anticipation and set it aside.
However, after seeing all of the changes passing by on screen during its follow on installation, rather than risk breaking the New Package that may have enough new modifications in code to make the whole Damned Thing NOT work as I proved it previously had, I just opted to repeat the Mod Process on modifying the ps2000.h file as before. And so once again, my inexpensive PICO Hardware STILL works with the High End PICO Automotive Suite. (Sweet) :>)
New member here. Big smile appeared on my face when I saw a Linux thread on the same site where my Trailblazer questions and comments will see light :) Nice to see so many users here. I'm a huge Linux fan and have tried so many flavors. It's addicting. I love them all but have always gone back to Manjaro which currently runs on this laptop I nuked Windows on :) There is something about Arch which gels with my soul. I always wipe and flush any Microsoft machines and put Linux on them. Hate to admit I'm still running a couple windows PCs but only because of the very picky software I need to use to run my business. However, Windows Subsystem for Linux is installed on all of them and keeps me sane when I need to use those.
Keep up the great post! Cheers!
@Blckshdw ... You and perhaps a few others in the IT world might already know about this incident... but since I recently stumbled over it while browsing Linux information from back around the Y2K Transition, when I saw the Advert, I laughed so hard I almost "P'd" in my pants. I'm sorry...but THIS situation was just too damned clever NOT to be Funny...
Something strange happened as I was watching the latest Starship Activity from the SpaceX StarBase down in Boca Chica, Texas from the NASASPACEFLIGHT Folks via their YouTube Channel this morning:
I noticed an odd “Wavy Gray Gravy Line” populating the lower portion of the YouTube Viewing Frame on their Web Page. I began to wonder if this artifact involved any issue with either my Dell Precision 4800 nVidia Work Station CAD Quality Video Card, the 32 Gigs of RAM on board or perhaps problems with any of the Quad CPUs installed inside of this otherwise perfectly reliable machine.
Then I realized that I’ve never had to Question or Test out the Very High Definition Graphics on my Dell Laptop Screen before, so I wasn’t certain about "What Computer Graphics Bench Mark Test Suite Should I Use?". After that, I ‘Goggle-Eyed” around and then found, downloaded and installed THIS Phoronix Test Suite for these purposes.
The is latest *.deb File for either the Debian and Ubuntu Linux OS:
https://www.phoronix-test-suite.com/?k=downloads
It follows that I installed the Phoronix Test Suite after opening a Fresh Terminal and Typing in these Commands after adding in my SU (Super-User) password as needed of course,
sudo apt install gdebi-core <E>
sudo gdebi phoronix-test-suite_*.deb <E>
I then clicked on the LM (Linux Mint) Icon in the Lower Left of the Laptop Screen and Typed in “PHOR” (sans Quotes) into the Search String Line. The Program TAB for selecting The Phoronix Test Suite appeared to the right and after clicking on it, a New Terminal Opened up and the Test Suite automatically ran its course in just a matter of minutes.
Once all of the Tests were complete, they listed out their very comprehensive results on the screen ...showing nothing untoward had occurred. Then I opened up a Fresh Terminal and typed in:
sudo apt update <E>
When I went back to look at the minimized YouTube Screen, that mysterious “Wavy Gray Gravy Line” artifact had disappeared completely. Problem Solved.
I'm not certain whether or not the recently updated Linux Kernel (Valentine's Day 02/14/2022) needed some Additional Love via another Update Refreshment to sort this out. Nevertheless, having a Decent Computer Bench Mark Test Suite that will work on Linux Mint, Ubuntu and Cross-Platform over to Windows OS Flavors as well ...is never a Bad Thing. :>)
That's That... And No Harm Done!
So... Imagine that you're in your own Home and you have your Laptop Open and Running on your Kitchen Counter and you want to share a Private Conversation you've just had while on Zoom with your Boss related to Work with your Wife. The Zoom Session has been off for over an hour or so.
But... How do you KNOW for certain whether or not your Microphone(s) and Web Cameras are Turned OFF on your Laptop Computer? Not Paranoid enough to be worried about this because YOU just happen to be an Experienced Linux User...?
And so You don't think your system has the same Miserable Vulnerabilities as the Average Windows OS User has to deal with? ...even given the present conditions happening around the World?
Hmmm... Better Think Again...
And Read THIS:
For any concerned Linux Mint Users … If you are using Google Chrome or any of its Variants as your Internet Browser and You DO have any worries that your Microphone might be getting Remotely Turned On without your Knowledge or Permission… Try using this “Little Script” that allows you to Check in ... and Toggle ALL of the Laptop Microphone(s) either OFF or ON whenever you are using the Linux Mint 20.3 OS on your Laptop Computers:
Remember.. using the <E> Enter Key after each Command Entry described below is an assumed action:
First, Open up a Terminal from:
Menu - Accessories- Terminal
Then... Select and Copy Everything below but NOT including the word ‘Code:' down to and including the expression ‘fi’
Code:
#!/bin/bash
# mic toggle
tgl=$(amixer -D pulse sset Capture toggle)
if echo "$tgl" | grep "\] \[off\]"; then
echo "Mic is toggled OFF"
else
echo "Mic is toggled ON"
fi
Next… While you still have a Terminal Open:
Type: nano mike.sh
When the Nano Text Editor Desktop Opens… Paste the Copied Coding from above onto the Nano Marquis (Desktop):
Then Press CTRL X and Save this File Name as mike.sh
Next... If you want to ...Open up a Terminal from
To create the New toggler Folder:
Type: mkdir toggler
Then Copy the mike.sh File over into the toggler Folder:
Type: cp mike.sh toggler
Then switch over to the toggler Folder (Change Directory)
Type: cd toggler
Then Check for the presence of the mike.sh File in toggler:
Type: ls mike.sh
The File mike.sh should the present as the only File in that toggler folder and appear in there as White Text.
To make mike.sh an Executable File …Follow THIS Tutorial:
Type: ls *.sh to ensure that mike.sh is still present in the toggler Folder you are in and shows up as White Text:
Then… Open up a Terminal from
Then … To make this mike.sh File Executable...
Type: cd toggler
Type: chmod +x mike.sh
Then … To confirm that the File Name Color has turned from White to Green, thus confirming that it WILL Execute.
Type: ls mike.sh
If you can see the mike.sh File name is now GREEN ... then it is Ready to Execute:
Now… To Toggle ALL In-Dwelling Laptop Microphones either ON or OFF by Executing mike.sh ...use these Commands while you are still INSIDE of the toggler Folder (Directory)::
Type: sh ./mike.sh to execute the file.
The Results of this action will appear 'On Screen' in Terminal like the image below, explaining that the Microphones have either been Toggled ON or Toggled OFF:
The SAME Command...
sh ./mike.sh
Performs BOTH Tasks:
"Keep Your Wits About You vs. Prying Eyes ... And Place a Piece of Black Gorilla Tape as a Folding Flip-Up Flap ...just above your Laptop Screen Webcam, too." :>)
An Homage to the Talents of@TJBaker57 ...
Linux and Arduino Geeks ...and Especially… “The Minty-Linux Freaks”… Cast your gaze at THIS Lil’ Enterprise from 'The Mind of Tim Savage' way back around 8 Years ago as a GIT Project for installing New Firmware onto an ATMEL EPROM Chip ATMEGA328P and then swapping them In and Out of a useful FG-100 Electronic Signal (Function) Generator Logic Board:
… He used THESE Instructions, along with installing the Linux Mint OS with the AVRDude Installation Set Up ...and of course, while using the GIT File Pile (Stuff) from HERE:
https://hackaday.io/project/7985-alternate-firmware-for-fg-100-dds-function-gen
https://github.com/timsavage/fg100alt-firmware/
https://www.instructables.com/How-to-Setup-AVR-Programming-Environment-on-Linux/
...and while using THIS Gear:
KINWAT ATMEGA328P EPROM Chip
ANBE AVR Programmer Kit (AVRISP Micro-Controller Programmer)
ELAGOO UNO ARDUINO BOARD
1720281444316293043.jpg2425241444316178667.jpg1861431449839536344.jpgELAGOOBOARD.jpgANBEAVRPROGRAMMER.jpgATMEGACHIIPS.jpg
...and while Following THESE Drop In EPROM File Instructions:
FG-100 alt firmware
Alternate firmware for the FG-100 function generator
The FG 100 is a cheap function generator widely available on Ebay.
See https://hackaday.io/project/7985-alternate-firmware-for-fg-100-dds-function-gen for details
Requirements​
You will need:
  • Obviously, an FG-100 (ebay is a good source)
  • ATMega328p 28pin DIP micro-controller
  • AVR programmer/ISP (the Makefile defaults to using a USBTiny ISP)
  • AVR toolchain (eg avr-gcc, avrdude and gnumake) installed
Warning: There are many sources for the FG-100 of varying quality and performance. My particular unit has a high quality PCB with quality components (Rubicon capacitors), the output is clean with minimal noise. Other people (including a review on Hackaday) have not had such luck. YMMV
If you are using a different programmer you will need to update the Makefile with the currect programmer code for AVRdude, update the AVRDUDE_PROGRAMMER parameter with the correct value for your programmer (see AVR dude documentation for info).
Compile/Install​
All development was completed on GNU/Linux so all instructions relate to this OS (feel free to generate a project file for AVRStudio and send me a pull request :wink: ).
Steps to build/upload/set correct fuses:
> make program
If you prefer to do the steps separately:
# Compile/Link/Generate Hex
> make hex
# Upload to microcontroller
> make upload
# Set correct fuses
> make fuses
Finally open up the FG-100, unscrew the LCD and remove the existing ATMega48 from it's socket, replace with your newly flashed ATMega328p, replace the LCD.
~ Enjoy!
avr firmware reverse-engineering
… and finally… Check out THIS Follow-On Project for ANOTHER Function Generator Build:
https://hackaday.io/project/19866-funktion-generator
As per their "Major Upgrade Every Two Years..." Policy, Linux Mint Version 21 "Vanessa" is now available to install over the latest active Version 20.3 "Una".
But BEWARE AND PREPARE when performing any Live Linux Mint Swap suggested below and steel your mind to ENDURE AN AGONIZING FOUR (4) HOUR PLUS PERIOD FOR ALL OF THIS TO COMPLETE.
During the First Hour, the User will have to ‘participate’ and respond to many interrogatories appearing in a Microscopic Font/Text in Frame as necessary in order to coax the Mint Software Update to continue doing its ordinarily Automated Job.
My suggestion is to arrange the Mint "Let's GO!" Install Panel side-by-side with the Terminal Screen Panel, so you can see everything that is transpiring.
The whole process eventually did finish with a Good Installation on my Dell Precision M6800 Work Station Laptop… But it literally felt like it took longer than a Lifetime (Well ...perhaps at least that of a May Fly) to arrive at this Happy Result.
Be advised that the “Vanessa” Install Programming Sub-Routines will find much that “upsets its tummy” coming from the Old Linux 20.03 “Una” Flavor via by bringing the activities to a Screeching HALT and providing frequent advisories in Blocks of Red Text whenever it locates Old Stuff that it finds “incompatible”. Just Go With It.
Hopefully… You’ve parked all of your important “Stuff” in Duplicate upon another Drive as the means to protect your sanity, should this installation decide to “Go Sideways”.
For example… it decided to arbitrarily do away with ALL of my PICO-Scope Linux Mint Version 6 and Version 7 Installations, along with a few other Installs of ‘non-standard’ Debian Source Code and their links and locations as well.
Watch for the various Buttons You Will Need To Press in order to allow things to proceed. In time, the hypnotic cascade of on-screen activity will either Fascinate you enough to want to Keep An Eye on on the Terminal Screen after each of these things is allowed to continue… or it will Lull you into a hopelessly Deep Trance.
But, before any or all of this Fun can begin…
DO NOT SKIP THIS NEXT STEP!
Prior to performing this sisyphean task, make certain to visit the link below and Install & Run the "Timeshift" App to Back-Up your files from Linux Mint 20.3 at least ONCE prior to attempting this Latest Linux Mint Upgrade from an Open Terminal in Linux Mint 20.3
Then visit and follow the Command Line Installations Instructions (using Copy-Paste) after reading everything posted on this site from Top to Bottom:
Enjoy Using Linux 21 (Vanessa)… and Let’s Hope that She Does NOT prove to be a “Harsh Mistress”.
PS… Be advised that some of your favorite Old, Familiar Applications” may HAVE been Modified in strange, non-intuitive ways that "Vanessa" will make to seem a lot less convenient.
For example, when using the “GWENVIEW” Image Viewer...They’ve moved the “SAVE” and “SAVE AS” Entries off of the Main Menu Tab normally located in the Upper Left Hand Corner, over to the Upper Right Side of the Screen... all by themselves. Well…? WTF…Dudes!!!
It’s really Not as BAD as it used to be… But for anybody who even accidentally brushes up against using ANY Flavor of the Linux Operating Systems, We all know and understand that “Linux Peeps… ARE … “Geeky Peeps”. Oh Man... Ergo, They always seem to want to make EVERYTHING more Technical and Difficult than “Things” need to be whenever We are in any “Terminal” and trying to use the “KISS” Principle with our Command Line activities.
Take for example … Just the simple process of Adding in a Second (Blu-Ray Drive) and then wanting to run a Quick Installation and “Set-Up & Check-Up”. Well… NOPE! Noggana-Do-THAT-Brah! But… As sure as There are Carts to Horses… There are always Even 'GEEKIER Peeps' around with the Chops to put together a Neat LIL’ Utilities Package to make our Linux Lives ...Just A Little Bit E-Z-R:
Now... Open a Terminal and ‘Copy – Paste’ in JUST THIS Hi-Lighted string:
...THEN ... (Press the Enter Key) <E>
sudo apt install libcdio-utils <E>
...THEN.. Use Your Super-Secret Root PWD <E>
Then, right after a Brief Delay for this Installation… ‘Copy – Paste’ in THIS Hi-Lighted Expression:
cd-drive <E>
...and then... Sit Back... And Watch the Cascade of the “Good Stuff” Populate the Screen.
Read MORE about this Helpful Topic HERE:
https://www.cyberciti.biz/faq/linux-find-out-the-name-of-dvd-cd-rom-writer-blu-ray-device/
Sweet? Oh Yeah, Baby... No Sweat!
Programming Arduino Hardware and Devices ordinarily requires using the Arduino-IDE software installed using a Windows Version of this application. However, for Linux Mint 21 Users... Here is another method for installing the Arduino-IDE App:
Even if you perform the necessary task of allowing the Linux Back Up Software called “TIMESHIFT” to run on a regular enough basis to collect a half-dozen “Snap Shots” of your Hard Drive… Things can STILL go sideways enough with the Drive itself to make it physically impossible to perform repairs upon it and fully recover the Operating System, the APPS on board and of course...the Precious Data left on 'The Platters'.
About two weeks ago, THIS Nightmare visited me at a time when my DVD Reader-Writer Burner was inoperable. That lead to me investigating the use of a Boot-able USB and running down a handful of different Recovery Programs that I discovered ...with some unfortunate time wasting uses that failed to work.
Now even though I was already familiar with CloneZilla as being THE Premier Program for Disk Duplication, Cloning and Image Creation… I thought because of my having some serious “Tech-Savvy Chops” that I would tinker around with ALL of ‘them others’ and see what worked best. That ridiculous idea lead eventually to my creation of a USB Based Boot-able ISO of CloneZilla… and the results that followed on during this “Recovery and Discovery” effort were nothing less than spectacular.
THIS is a Great “How To” for using CloneZilla worth Downloading, Saving and Reading Cover to Cover:
https://www.systranbox.com/getting-...ep-guide-to-cloning-and-backing-up-your-data/
The MOST important observations are worth mentioning and raising the awareness about on certain actions that CloneZilla engages in that are almost Magical IF you are wise enough to purchase a replacement Hard Drive of the SAME STORAGE SIZE… but not necessarily having an Identical Make and Model Hard Drive ...even though THAT is probably the best way to approach setting things up.
THESE are the Instructions on How to Prepare a Bootable USB for CloneZilla ISO “As EZ as PIE” on Linux Mint...or for Windows if needs be...or ANY other ISO you choose:
And for Ubuntu Users:
https://www.howtogeek.com/414574/how-to-burn-an-iso-file-to-a-usb-drive-in-linux/
THIS is THE Most Important Thing Worth Mentioning…
If your Hard Drive eventually suffers from ANY Physical Damage, avoid using it at all by Reading and Writing to it. CloneZilla has a Suite of “On-The-Fly Read, Repair and Recover the Sectors” Features that are simply amazing.
So as in my case, you would be able to Clone everything from a seemingly Damaged Drive using CloneZilla and then allow the System to Boot Up from One of the Emergency “TIMESHIFT” Snap Shots you previously created and have available under the “Advanced” Features on the GRUB Boot Menu from your New Hard Drive and this should be able to recover the Bulk of your Original System onto the New Hard Drive.
MAN… WHAT A RELIEF!!!
PS… If you are “Geeky Curious…” You can Watch each phase of this CloneZilla process pour out On Screen and learn much more about all of the hidden stuff working away to make this all possible. It IS Wildly Entertaining!
Some Helpful CloneZilla Videos:
Even if you are NOT using any flavor of the Amazing FREE Linux Operating System... if you are browsing the Internet on your Windows or MAC Desk-Tops and Laptop Computers WITHOUT having a decent VPN (Virtual Private Network) installed in this Day and Age of all the Hacking and Cracking...
Please... Consider Having Your Head Examined!
No...Seriously though... Right now, you can find FREE Full-Featured (up to a point) VPN Services on line without much of an expense OR difficulty with setting one up on your system.
I patronize several different, Inexpensive "PAY" versions of VPN Systems for the sake of being able to make various comparisons between the one I use on my Android Cell Phones vs. the one I use on all of my Linux Mint and Debian Servers and Laptops.
For the "Dyed In The Wool" Linux Mint Lovers... Check out THIS Video for all the reasons to consider doing this ASAP if you are presently surfing and are unfortunately completely naked and unprotected on-line. Enjoy the Step-By-Step Instructions that provide all of the "Neath The Skin" details of these procedures:
If you want to get a "One Over The World" look at your what your Linux Operating System including All of your Internal Computer Component Systems and your Hardware Identification and Performance Specification should looks like in One GO... Just Open a Terminal and Copy Paste in THIS Simple Command String:
inxi -Fxz
After it prints out all of this information on screen... Copy EVERYTHING ...from Prompt to Prompt ... and then open up a Fresh Document in LibreOffice and Drop that Data into the Document. Save that Document with a Familiar Identifier such as "ALLLINUXSTUFF" so you that can observe and refer to it from time to time.
And... You're DONE! :>)
Even though for the most part... The Linux Kernel is fairly immune (except for ROOTKITS) to the greater volume of Virus Threats that ordinarily plague the Computers sporting ALL versions of the Windows Operating Systems and perhaps even the Apple MACs as well. In THIS day in age, what with the Russian KGB & GRU Hacker Operations persistently screwing around within the countries information systems and peoples around the Free World... it might be better to Download, Install and Maintain a decent Anti-Virus program.
For those of us using any variation and flavor of Linux... obtaining CLAMAV is the Very Idea in mind (and in particular...its latest version of a GUI interface versus the ordinary Command Line Interface) .... Visit THIS Link and READ EVERY OPTION from Top To Bottom and install the most appropriate features that will go a very long way to increase your sense of protection and security... as Ever... Completely FREE OF CHARGE:
PS.... Don't have a Paid VPN Service for ALL of your devices ...Yet? WHY NOT? The REALLY Good Services that include a KILLSWITCH feature is the way to go... Shop around and Choose WISELY. FWIW, I've been using PIA (Private Internet Access) for my systems and found a HUGE Bang for my Buck by doing so:
In the wake of any possible illegal activities happening in our communities that might involve Identity Theft, Hardware and Cell-Phone Hacking or YOU NAME IT! From a local High School Kid who stumbled across the KALI Linux Tool Kit and has decided to perform "UNETHICAL HACKING" ...to some genuinely terrifying threats coming from the Russian GRU and KGB International Spying Activities that have managed to make inroads into Europe and of late, *tinkering* within our own political spectrum.
**** Think I'm kidding? Who do you think has been running around all over the country and dramatically shooting up the various Power Station Electrical Grid Control Boxes, trying to take them down?
Spend some time with Liron Segev via THIS YouTube Channel and work your way through each of his tips. Download and SAVE his Videos for Future Use and be just a little more suspicious if you are experiencing any "Odd and Weird" Things with your Cell Phones, Messages, Emails and Streaming that make the hairs on the back of your neck...stand UP. You Do NOT have to be a KALI Linux Aficionado to find great benefit from what follows on below. Windows and MAC Users should look in these Videos, too:
If you have not as yet decided to Download and Burn the Latest version of Linux Mint 21.2 "Victoria" either on a DVD or on a USB Thumb Drive to run any time you like for experimentation and want just a brief overview of what this Operating System Looks with its Latest LTS (Long Term Support) bumping it up to 2027... View THIS Video and drop in on the Linux Mint Download Page...and Help Yourself to Something Brand New ...and FREE!
Another Review...of a "Nearly PERFECT Linux Operating System":
...and Last But Not Least:
The Official Linux Mint Site:
Hi, thanks to your post I have installed linux for the first time in my life. Are there now any options to run 2204A together with Picoauto 7?
I followed your instructions, but the libps2000 folder is completely missing in the installed version 7.1.18-1r17.
  • Love
Welcome to GMT Nation to @Ignatovd over in Brest, France....
Give THIS Native Pico-Scope Software Instructional a look and see if anything comes to mind:
I would avoid using the PICO Automotive Version 7 and stick with the Version 6 Automotive Suite because even on Windows Machines... the Version 7 can either disable or disadvantage Users working with some of the features; just as it is with the Linux Operating System Platforms.
My suggestion would be to Experiment with the FREE Version 6 Automotive by practicing on a Vehicle in Good Running Condition... taking many "Known Good" Wave Form Samples and saving them in your "Mechanic's Wave Form Library" while you become more and more familiar with your Oscilloscope Hardware and ancillary equipment.
I am so very glad that this approach has worked for you. Please feel free to contribute more of your experiences over time. We are here to Help!
Reactions: Ignatovd
Forgot to make mention that we have a Dedicated Oscilloscope Thread available for Users of Windows and Linux Laptop Based Autel, PICO-Scope and Hantek Units as well as for Stand-Alone Systems like Hantek Hand-Helds and MICSIG Units too ...over HERE:
  • Love
Reactions: Ignatovd
This Video shows SIX LLM (Large Language Models) AI Shoot Out:
LLama-GPT: Self-Hosted Off Line and Private:
If you have been perspicacious and already Downloaded and Installed your Own Off-Line, Private LLM Program and want to install an easy to use LLM based Open Source Programming Language Interpreter… Visit This Link, follow the instructions and use PIP to set things up:
https://github.com/KillianLucas/open-interpreter
This Tutorial will take your through what becomes possible with using this Open Source (Non-OpenAI Non-Token Driven) Programming Language Interpreter:
If you've recently observed a message for your Synaptic Graphical APT Application that there is an option lately made available to Upgrade from Linux Mint Version 21.2 "Victoria" over to Linux Mint Version 21.3 "Virginia", I am making a few observations worth noting.
If you are unfamiliar with these "Upgrade" vs. "Update" procedures and you are having any qualms about doing this... One of the changes I observed after making this transition (quite seamlessly, actually) was that once the Linux Mint Version 21.3 "Virginia" Upgrade was concluded and I Re-Booted my Dell Precision M6800 Work Station Laptop... As soon as the GRUB Menu appeared (GRand Unified Boot Menu) after the Boot-Up and POST events had completed, there was an Option on the Menu to Select and Use the OLD Linux Mint Version 21.2 "Victoria" OS.
So, if it turns out that your Machine Misbehaves or will NOT properly run the latest Software Upgrade for any reasons, choose THIS Option before the Machine Auto-Boots into the Latest OS. I cannot recall ever seeing this Particularly Handy Option on the GRUB Menu being available during prior Upgrades, and it is a much nicer feature than having to rely upon using the Old Tried and True, Time Tested "Timeshift" Snapshot Feature to return the Laptop to any prior working versions of the Linux Mint Operating System. Good Luck with your pending OS Upgrade!
PS
Obviously, if you've been using the "Timeshift" App for your Back Up Procedures, then if you are satisfied with the way the Latest OS is working... Visit the "Time-Shift" App and perform creating a Snapshot of this Latest Upgrade... ASAP and KEEP a few Copies of the Prior Snapshots for the Linux Mint Version 21.2 "Victoria" as well...Just In Case... for the Time Being.
I just took a BIG Bounce UP in Laptop Tech with the acquisition of a Dell 7720 Work Station sporting TWO NVME Chip Slots that allows me to "SKIP THE GRUB MENU" (even though I seldom if ever miss a meal... LOL) and thus, I can keep the Dell OEM NVME Windows 10 Professional OS Stick in its original, pristine condition and NOT have to partition it into NTFS ...AND... Ext4 for adding in the Linux OS Stuff usually necessary for setting up any Dual Boot configuration.
At some time in the near future... I'll park BOTH NVME Cards along side of each other and then, whenever I want to use either one or the other... I'll Hit the F12 KB Button during Boot Up and then select the OS NVME Drive of Choice ...and use one or the other, without risking any corruption to either side! SWEET! I LIKE it!
Incidentally... I also installed a 2TB Seagate HD formatted in FAT32 so BOTH the Windows 10 Pro and the Linux Mint 64 Bit OS can SHARE that Storage.
To accomplish this... I sprung for a Second NVME Chip in the 2TB Flavor and installed the latest (almost) version of Linux Mint Ver. 21.3 onto it, after first carefully removing the OEM Window 10 PRO NVME Chip off of the MOBO and make the slot free for the Linux OS Installation on the New NVME Chip.
It follows on that the necessary"Post Installation House Keeping Rules" always include my concerns about Internet Security with my PIA (Private Internet Access) VPN Account set up, using the Water-Fox Browser along with DuckDuckGo as my Search Engine and ensuring that the included UFW Firewall is set to ACTIVE.
And so... this process continued on while working through a whole raft of other nifty activities to make the system run a bit better, such as obtaining & installing the latest Proprietary nVidia Drivers for my P5000 4k GPU Card, etc. Meanwhile, I was also poking around on YT and while sly looking around for any New Security Wrinkle Videos worth sharing on this Thread and these two emerged as some of THOSE:
THIS One will be Thought-Provoking for any SysAdmins in charge of any Linux Servers... It's always a Good Idea to be willing to learn New Things about On-Line and In-House Network Security... :>)
If you are looking to improve your acumen on a Whole Wide Range of Operating Systems ...using Windows, Linux, iOS, MAC-OS, Android and more... in particular involving Security and Forensics... Drop in on THIS Link and then "Pick Your Poison" from a raft of Technical Articles worth downloading into a useful Computing Tech Library.
You never know when being able to refer to it for much of the *Stuff* that only the truly technically trained know about might just come to your rescue:
It's No Secret... that I am not shy about using the Linux Mint Terminal and employing command strings to control pretty much of everything necessary to get things done with Linux. However, when it comes to finding a REALLY useful GUI App for Downloading Videos... the effort in locating a truly USEFUL version of something that can handle both FFMPEG ...AND... YT-DLP for Downloading YouTubes ....has been a Long Road...with No Turns.
That is... until NOW:
Enter: VIDEOMASS. THIS is a VERY Cool and Full Featured GUI App that allows the User to do a wide range of things with Videos and Images...including being able to Concatenate Short or Segments of Longer Videos into One Longer Video. The Drag and Drop Feature for grabbing Video URLs instead of performing this arduous task in a Terminal with the Classic String: yt-dlp <URL> can now be a thing of the past. Besides that... the GUI is VERY Attractive and EZ2 Use:
The Attached PDFs will provide all of the details for the Theory of Operation, Layouts and for the DL & Installation:
I usually post Oscilloscope Information HERE:
However, since this Topic specifically deals with "How to Download and Install the FREE Pico-Scope Oscilloscope Automotive Diagnostic Ver.7 Suite" suitable for Linux Versions that are of the Ubuntu 22 LTS OS Flavor (Also for the latest 2025 Linux Mint MATE (Xia) 24 LTS OS Version) ...THIS is the Link to use.... And Remember to ...FOLLOW ALL OF THE INSTALL STEPS LINKED BELOW:
Further, I have just upgraded my Linux Mint OS from the 22 Ver. (Wilma) over to the 22.1 Ver. OS (Xia) ...and have confirmed that the instructions below DO WORK.
The Pico-Scope Suite Downloads and Installs properly. However, since it does NOT come with a GUI interface... The Suite MUST be launched from a Terminal after navigating to the sub-folder listed as "bin" and then the BASH Command must be activated using THIS Command:
./picoscope
Note: It is NOT necessary to "chmod +x" the BIN file app "picoscope" in order to make the program Executable in Linux... IT is Ready-2-Go:
As you can see, this invokes the proper APIs and functionality just as though it were operating on a Computer using the Windows OS:
The Pico-Scope SW Closes once the Terminal is Closed... so SAVE your Live Diagnostic Work often as you make progress and avoid accidentally or unintentionally closing the Oscilloscope Program in Live Settings.
-=Enjoy!=-
This Topic is EXTREMELY Important...
With the state of the World being as it is and with the emergence of New Technologies that can store our personal information and activities, it will become more and more critical to ensure that such information does not fall into the wrong hands.
Theft and the Re-Selling of Laptops and other devices that can be used for Espionage, Blackmail, Economic Gain and Personal Harassment should be front of mind for ALL of us and actions necessary to avoid these possibilities CAN be pro-actively taken.
New Data Storage of a "Permanent" Nature that we would ordinarily think can be destroyed with the Old Hardware conventionally prior to either selling or disposing of it for destruction requires a different approach to this problem. Simply "Re-Formatting The Drive(s)" ... Will NOT Work!
For Linux Users that have NVME M.2 SSD (Solid State Drive) Tech inside of their Computers and Play-Stations... The Best Procedures for the initial setting up of the Ubuntu-Linux Mint Debian style Operating Systems on such "Hardware" requires Formatting the ENTIRE SSD using an Encryption Protocol making it impossible to recover ANY Data without the initial Set Up Key.
The Second Method for Linux Mint Users who do not want to lose their existing set-up is to install the "secure-delete" Application using the typical Terminal Command Line Expression:
sudo apt install secure-delete
Then read the MAN Pages (Manual Files) and watch the available YouTube Videos in order to become familiar with how to BE CAREFUL WHEN permanently using these actions to over-write and remove all of the files within certain folders... including the folders themselves in a maximally secure manner. Once DONE...They are GONE.
As these instructions will demonstrate, THIS multi-Action process CAN be done... but may become tedious and unreliable over time for those who regularly handle sensitive data, B2B correspondence and proprietary imagery subject to Industrial Espionage or actual "Enemy State Actors" from certain countries and others not inclined towards protecting the Privacy and Democracy of the Western Hemisphere and elsewhere on the Planet.
It is also recommended that the application called "shred" (which is already installed on the Linux Mint OS) be employed PRIOR to the deletion and removal of any files and folders...followed by using the "secure-delete" actions. AVOID DELETING FILES ON NVME M.2, USB TYPE OR ANY OTHER SOLID STATE DRIVES OF ANY KIND. Because... IF you do NOT know WHERE they are...You Cannot Over-Write Them!!!
The important understanding here is that unlike a Physical Turning Platter spinning within a typical Hard Drive... NVME M.2 and USB Stick Drives stores their information with a completely different set of protocols because the "Boxes" or "Spaces: where the the data is parked...Does NOT move.
Ergo... the only action that can be taken is to repeatedly overwrite those locations and then programmatically obfuscate the original file naming and pathing information on the deleted folder locations to securely eliminate any possibility of Data Recovery.
The suggested Technique for establishing a FULLY Encrypted NVME M.2 SSD that is NOT presently protected is to do THIS:
(1) Obtain an Identical NVME M.2 SSD and exchange it with the Original NVME M,2 Drive... long enough to FORMAT, FULLY ENCRYPT AND INSTALL A FRESH INSTALLATION OF THE LATEST VERSION OF LINUX MINT (22.1 -Xia).
(2) Exchange the Brand New NVME M.2 *Stick* for the Original NVME M.2 SSD and create a COMPLETE Back Up of the Old Drive using the "TIME-SHIFT" Program and save that file to a Large USB RAM *Stick*.
(3) Then ...once again... Exchange the New NVME M.2 *Stick* for the Old NVME M.2 SSD and after Booting up to the Linux Mint Desktop.. Run the "TIME-SHIFT Application and "RESTORE" the Back Up from the Old NVME M,2 SSD onto the Brand New ENCRYPTED NVME M.2 SSD....and Then... Boot it Up and Test it OUT!
(4) Success with this technique may be a little sketchy...so examine the Directories and Files and ensure that the Bulk of whatever you wanted to protect is actually accessible and usable before you *CRUSH* that Old NVME M.2 Stick to Atoms using a Ten Ton Arbor Press to put your mind at ease.
(5) Be advised that using these Techniques for Data Elimination can cause the Premature DEATH of all Solid State Drives from having Excessive Writing and Re-Writing to the same locations. So having the Drive Fully Encrypted at "The Get-Go"...is the Best Policy to follow for the Long Haul.
Stay Safe and Stay Secure... :>)
Bonus Footage:
Following on from the Last Post... I decided to "Consult The AI Oracle" I use (Completely Off Line) called GPT4ALL in regards to the possibility of converting an Existing Non-Encrypted NVME M.2 SSD over to FULL Encryption and NOT "Lose Even One Byte".
GPT4ALL: Free to Download, Install and Use OFF LINE on Local Installations to either Laptops or Desk-Top Computers:
These Ten Consecutive Screen Prints cover that entire conversation "WE" had and I note that even those with "the meanest of understanding" of using BASH Command Line Instructions in the Terminal (ME) will have no trouble performing these rather technical procedures.
Having had earlier experiences when using both "DD" Commands and the application made famous for making Disk Copies in Linux possible called "Clone-Zilla" will certainly help me with making these procedures easier to follow.
The other aspect of interest is that thankfully, my Dell Precision Model# 7720 Work Station is equipped with TWO PCIe NVME M.2 SSD Slots AND one additional SATA Port and space for an in-dwelling 2 TB Seagate 2.5" Hard Drive that as it happens...becomes ABSOLUTELY NECESSARY for any of this to work. GPT4ALL explains it all... Oh So Well.
ENCRYPTEDHD1.jpgENCRYPTEDHD2.jpgENCRYPTEDHD3.jpgENCRYPTEDHD4.jpgENCRYPTEDHD5.jpgENCRYPTEDHD6.jpgENCRYPTEDHD7.jpgENCRYPTEDHD8.jpgENCRYPTEDHD9.jpgENCRYPTEDHD10.jpg
And for just about "The Best Clone-Zilla How To" Video available...THIS is the One You Want to Watch:
...and maybe ...THIS One, too:
This is a rather lengthy Follow Up to more fully explain the implementation of the use of LUKS when starting out with its use at a Formatting Level of the Hard Drive, or in my case, a Second 2 Tera-Byte Samsung SSD that is housed and powered inside of a 2.5" SATA Drive within my Dell Precision Model# 7720 Work Station Laptop:
(1) In Review...if you are wondering WHY there would ever be any urgency for preparing a place for Data that is only accessible to YOU...is to start with the issue of One's Own Mortality. I am approaching 76 Years of Age now...and I have to be realistic about the fact that there is far less "Candle and Wick" left for lighting the way for my existence to continue than ...thankfully... for most of your lives.
But... Our Mortality is seldom completely predictable, thus possibly being Caught...Unawares... would most likely be the Rule rather than the Exception. So... Semper Paratus! Seems like the proper way to proceed in this matter.
It follows on like "Carts to Horses" that since I have no idea what will happen in the future after my Death to any or all of the vast Computer Equipment I have been accumulating and using going back to the early 1980's when the name "Silicon Valley" was just becoming vogue... I want Neither Family Members Nor Strangers wandering through any of my "Stuff" under any circumstances. I have lived a decent life as a Private Person and I would like my Privacy to continue on 'ad infinitum' ...even after my Death.
(2) With all that said, if you find that you too have a similar desire or need to be just as perspicacious regarding your own Storage of Information, then the Linux LUKS Feature makes this process QUITE POSSIBLE---> BUT IS NOT VERY STRAIGHTFORWARD.
This is because several things must take place after you settle on using the EXT-4 Kernel (THIS Stuff will NOT Work With Windows) and establish a *Pass-Phrase Key*... This process is only the beginning of what must be done to make the Encrypted Drive WORK and soon become Useful to You as The Means of Having Protected Secondary Storage Space on Your Hard Drives.
(3) You must understand that Data Encryption is meant to function WHEN THE COMPUTER IS TURNED OFF AND LEFT UN-ATTENDED. If your security concerns involve other Privacy or Theft of Intellectual Property Issues prevail during "Live Use" ... Then LUKS Encryption will NOT solve those issues. IT is only meant to protect your Hard Drives in situations of *Bare Metal Thefts* or Investigations or Invasions of Privacy once the Machine(s) are Turned OFF and LEFT UNATTENDED.
(4) The Marvelous way that LUKS works is that "IT" sort of "Wraps Itself Around The Kernel" at Boot Up like an Anaconda Snake, such that in the absence of having that proper *Pass-Phrase* available, unlocking the Drive(s) and getting to the Data contained therein becomes virtually impossible.
In order to do this, this technology sort of *Blends The Pass-Phase Key* along with the UUID as the Hyphenated, Alpha-Numeric and Lengthy ID of the Drive Itself together in order to Wind itself around the Kernel like a Reticulated Python and render what happens after the Drive is LOCKED nearly impossible to get around. Lost your *Pass-Phase Key*...? Then YOU HAVE LOST YOUR DRIVE FOREVER.
(5) The Problem here though is that Our Folks must really understand WTF they are doing here ...because the feature of LUKS Implementation is only the First Part of this Process of creating a Hidden, Obscure Partition as the First Layer of Drive Access. The Second Actions requires the installation of the EXT-4 Kernel and other Programming ...making it possible for the Linux Kernel and Operating Systems to access and use the Drive in the usual manner.
In other words....Once *Un-Locked* There are no Special Adjustments or Adaptations involving either Linux Applications, Files and Folders Structuring or anything else occurring to impede the normal operations and use of the Computer. It is Paramount that the Un-Locked Drive be certain to DELIBERATELY LOCK THE PROTECTED DRIVE PRIOR TO SHUTTING DOWN THE COMPUTER!
(6) So AFTER installing LUKS on the Drive(s) it will still be necessary to Install that Second Linux OS EXT-4 Layer. Then after that is successfully completed, then the Drive becomes useful for Creating Folders, and Transferring Files To and From the UNLOCKED Drive ...for the time that the Drive is OPEN via the use of the *Pass-Phrase Key*.
The Linux Application called "Disks" makes this issue easy to work with by observing the Drive Partition Layout Screen and THEN looking to read whether or not the Drive is "Locked" or "Un-Locked" via a Small Black Icon of a Pad-Lock. When the LOCK Icon is Clicked, the User faces the Entry Point for typing in the *Pass-Phrase Key*. Once the Right Key to the Drive is entered and it OPENS... then otherwise Normal Drive activities becomes possible.
(7) After installing the Linux EXT--4 LUKS Layer and the Second Linux System Files for operational purposes, the issue of Files and Folder Security still remains. And its HERE that things can get a bit more complicated, because in order to use Linux File Destruction applications such as "Shred" and "Secure-Delete"...orders of operation action with command line instructions using the Terminal ...MATTER.
(8) The Hidden Partition Drive Naming Conventions including the UUID MUST be adhered to in order to designate WHERE the Unlocked Files and Folders reside.THIS gets a bit technical because it always includes the Protected Drive's UUID in the Directory and Folder Naming Conventions. So great care must be used when discovering and using that information accurately while running these Programs at the Command Line Level in a Linux Terminal BASH Screen.
(9) In orders of Operation, The Protected Hard Drive or SSD must first be Un-Locked with a Pass-Phrase... Then the Linux Terminal must be opened and then after using the correct information to identify the Hidden Files and Folders...FIRST... the "Shred" Commands are used within each respective involved Hidden Folders to Shred those Files... "In Situ".
(10) Then, the *Secure-Delete" application is invoked from the Root Directory of the "C" Drive in the Command Terminal String to completely identify and use the Correct PATHING to the Folders and Files to be Destroyed by the *Secure-Delete* Application (SRM).
Unfortunately, All of this will take a lot of time, depending upon how many files are involved and likewise how many folders since each folder must be individually identified so as "Not to OVER-DO it..." and Wind Up ...Wiping Out The Wrong Files!
More To Follow Later On Concerning Terminal Command Syntax, Etc.
For those of us who have been around since the advent of the IBM XT Desk Top Computers that soon after allowed for an OOP (Object Oriented Programming) to evolve into Windows 95 and Windows NT... we can all remember just how convenient the App called "Microsoft Paint" was ...and still is.
The problem begs why Linux Programmers' sideways version for GNOME Paint is neither as full featured nor as easy to use. Well... Drop in HERE if you want to download and install THIS App called DRAWING ...using FLATPACK... and see what a difference THIS one can make in Basic Image Manipulation:
This seems like it should merely be a matter of a "Trivial Pursuit"... but when it comes to adding and later MODIFYING THE ICON of a Linux Mint MATE Desktop Launcher... It can often be like Pulling Teeth with A Rusty Pair Of Pliers. But... I have finally figured out the EZ Way to get this Job DONE:
(1) Locate the Desktop Folder and (R) Click on it to reveal the Icons in the Folder:
(2) If you created your own Application Launcher already that does NOT appear in the Applications Menu... it probably has what looks like a Tiny Printed 8" X 11" Page as the Default ICON on your Desktop. But in this instance... THIS is the One I Wanted!
(3) So... The Simple Way to CHANGE the Icon to the Modified JPG Image of your Choice is to first install "GEDIT" as a YATE (Yet Another Text Editor) that is truly SWEET! by using this command string in a Terminal as follows:
sudo apt install gedit
(4) Then... (R) Click on your Old Launcher Icon in the Desktop Folder and Open it with the freshly installed GEDIT. You should see something like THIS...
Notice that I have already ADDED IN THE ABSENT ICON LINE as "Icon=" followed by the FULL path to my Newly Created WATERFOXICON.jpg and it looks like THIS on my Desktop and it LAUNCHES the Waterfox APP correctly:
Then... Click on "Save" and close GEDIT... If it works...You should immediately see the New Icon Appear on the Desktop ...and appear in the Desktop Folder.
And THAT ...is all there is to THAT... :>)
PS: ...and Speaking of "Trivia"...as it concerns the naming convention of the Linux Mint Desktop Environment called "MATE" which is NOT pronounced like it is Spelled... but rather spoken as "MAH TAY"...here it comes... straight from:
The MATE Desktop Environment Design Team:
If lately, you have discovered that attempting to Download YouTube Videos has been Failing.... Follow THIS Instructional Thread and simply UPDATE the "yt-dlp" Command Line, Non-GUI feature:
Code:
sudo yt-dlp -U
Recently, Microsoft made an "Adjustment" to its Business Model with the insistence that ONLY the Microsoft 11 Operating System will do and so Windows 10 is OUT! Now that may be all well and good for those of us using the Linux Operating System... BUT if you are used to visiting MSN.COM and clicking on the "Outlook" Button to get your HOTMAIL, etc... Guess what... IT MAY NOT WORK ANYMORE !!!
However, those of us who Dwell In Linux Land still have all of our Teeth...and a Few Friends Left in Town...and that includes having OTHER Options to get our Email using the GNOME Evolution Application.
And so... I thought it made sense to check with my Resident, Off-Line and Private AI GURU -=*GPT4ALL*=- and see if it would not mind guiding me through what might ordinarily be a *sketchy & scary* set of Installation and Set Up Procedures...since I was stymied when visiting the MS Outlook Page and unable to get around the latest changes that prevented access to my Outlook Account.
*GPT4ALL* produced THIS Checklist to Follow...and Brother...was IT ever EZ to Follow! THIS JUST WORKS!!! Just be patient while each Outlook Sub-Folder refreshes and then your Email will look and behave very similar to what Outlook looks like....and you will NOT have to Purchase Cloud Storage just to make the damned thing work like on Windows 11.
The Linux Mint 22 Gnome Evolution Installation follows on from HERE:
Prompt: How do I set up the Evolution Email Application in order to get my email from my Microsoft Outlook site onto my Linux Mint 22 Machine?
Response: To set up the Evolution email client to retrieve your emails from Microsoft Outlook, you'll need to configure it with IMAP (Internet Message Access Protocol) settings. Here's a step-by-step guide:
**Prerequisites:**
1. **Microsoft Outlook account**: You have an active Microsoft Outlook account.
2. **Linux Mint 22**: Your Linux distribution is up-to-date and running on your machine.
**Step 1: Install Evolution Mail Client**
Evolution is the default email client in many Linux distributions, including Linux Mint. If you haven't installed it yet:
```bash
sudo apt update && sudo apt install evolution
**Step 2: Configure IMAP Settings for Microsoft Outlook**
You'll need to set up your Microsoft account on Evolution using IMAP settings.
1. Open **Evolution Mail Client**: Search for "evolution" in the Linux Mint menu and launch it.
2. Click on **File > New Account...**
3. Select **Mail** as the type of account you want to add, then click **Next**.
4. Choose **IMAP** from the list of available protocols, then click **Next**.
**Enter your Microsoft Outlook IMAP settings:**
* **Host**: `outlook.office365.com` (or your organization's custom domain if applicable)
* **Username**: Your full email address (`username@domain.com`)
* **Password**: Your password for your Microsoft account
* **Security**: Select **SSL/TLS** as the encryption method
5. Click on **Next**, then select the folders you want to sync (e.g., Inbox, Sent Items, etc.).
**Step 3: Configure SMTP Settings**
You'll also need to set up an outgoing mail server for sending emails.
1. In Evolution Mail Client, go back to the account settings by clicking on **File > Account...**
2. Select your Microsoft Outlook IMAP account and click on the **Edit** button.
3. Click on the **SMTP Servers** tab.
4. Add a new SMTP server:
* **Host**: `smtp.office365.com` (or your organization's custom domain if applicable)
5. Click on the **Save** button to save these settings.
**Step 4: Test and Enjoy!**
1. Close Evolution Mail Client, then reopen it.
2. Check that you can send and receive emails from your Microsoft Outlook account using IMAP in Linux Mint's Evolution client!
If you encounter any issues or errors during this process, feel free to ask for further assistance.
Hope this helps!
Everything listed above was completed during the Automatic Installation... I just provided the Key Bits of information about my Outlook Account... and it seamlessly set the system up! And the BEST Part was that I could send and receive Emails again... without having to resort to using a Browser or visiting MSN.COM to do the job! SWEET!
One Last Word.... If you get THIS Error Message after installing Windows 11...
"You’re out of storage. You can’t send email, and won’t be able to receive in 18 days."
Then you -=WILL=- be held hostage by Microsoft and have to purchase additional On-Line Cloud Storage from hence forward...or Kiss your Email Account... -=Bye-Bye=- :>(
*Bump* The Video from the "Expert Dude...That Abides..." in Post #74
Over the last few years I've made a fairly facile argument for switching from the various flavors of the Windows Operating System to the FOSS (Free and Open Source Software) of the various flavors of FREE Linux OS Variants. But NOW things have gotten almost dire for anyone concerned with virtually ALL of their Privacy being compromised by the Pilot AI Dominated Windows 11 Environment Feature named "RECALL".
Pointing out the frightening reality that every Three Seconds... "RECALL" will capture a Screen Shot of ANYTHING and EVERYTHING your are doing that shows up On Screen and saving it into an encrypted file you cannot access that literally "Phones Home" to the vast MS Servers to be digested and analyzed and reported if deemed "Out Of Spec" for the AI's Behavioral Study Algorithm ...Considering switching from Windows over to the Very Friendly Linux OS Environment could NOT be happening at a better time. What YOU can SEE... THEY Can SEE!
THIS Video is strictly helpful to Windows Users who have been sitting on the fence about making what might seem like a daunting transition ...but which will be as EZ as Falling Off a Log with ALL of the Step By Steps needed to allow you to do this... Perhaps even while using your Old Windows 10 Computer which may NOT support Windows 11... -=BUT=- The FREE Linux OS Install will LOVE You For It!
I am very fortunate in having very high end Dell Work Stations-Laptops-Servers that sport M.2 NVME Drive Slots in abundance. However, if you have any Legacy Laptops sitting around that are tempting you as Windows Users to follow the advice of GETTING A LAPTOP SET UP WITH THE LINUX OPERATING SYSTEM... to experiment with and get your feet wet... BUT...you also want to boost the Old Hardware Performance over to a -=FAST=- Solid State Drive... THIS Video will interest you in the extreme:
Converting a Wireless Card Slot Over to Accept M.2 NVME Drives:
Since the New AI and Cloud Dominated Windows 11 Machines may not permit computer owners to Clone Their OWN Hard Drives anymore... I'll drop this issue here on the Linux Thread. Be advised that if your system sports the Latest, Fastest and Most Powerful M.2 NVME Drives like the Samsung 990 and 9100 Models that possess BLINDING Read-Write Speeds...if you decide to clone that drive over to a LARGER Drive possessing the identical parameters between the two THIS WILL NOT WORK unless you employ a Lithium Ion Battery Pack with sufficient storage to allow the high speed transfer at 20 Gigabytes Per Second.
The solution I arrived at was to employ a SUITOK M.2 NVME Cloning Station powered up by a TALENTCELL Lithium Power Brick after all other methods using Wall AC to DC Power supplies FAILED. The issue was that the Samsung 990 Donating *Stick* supplying the 2 TB files over to the Newer Samsung 9100 4 TB *Stick* put such a throughput demand on the Cloning Tool that the AC Adapter could NOT Keep Up with this extreme transfer rate. However... The TALENTCELL Lio Battery Pack ...COULD:
SAMSUNG9100NVME.jpgSAMSUNGFASTNVME.jpgSUITOK20GPSCLONER.jpgSUITOK20GPSCLONER00.jpgSUITOK20GPSCLONER2.jpgSUITOK20GPSCLONER3.jpgSUITOK20GPSCLONER4.jpgSUITOKCLONERSNEEDEXTPWR.jpgTALENTCELLBATTYPACK.jpg
This allowed for a PERFECT Clone of my Linux Mint 22.2 OS and ALL in-dwelling Files...with NO SWEAT!
Users of Linux Mint and other Flavors of Linux will probably be at least a little familiar with using the Terminal Bash Script called *yt-dlp* followed by some single URL from YouTube to Download Videos, Music and Audiobooks... One At A Time... even when there are Play Lists present.
But... What if you want to Download an entire segmented Audio-Book or Long Training Seminars that are only available in Byte Sized Chunks?
It follows on that we may not be familiar with -=ALL=- of the Feature Rich aspects that this amazing Python Program is capable of achieving, so in order tp *Tune Up Your Talent* with this Tiny ...but Powerful Application... Visit THIS Link first:
Then Stop By HERE and Pick Your Poison from among all of the available YT Training Videos covering *yt-dlp*
Then -=SAVE=- the attached PDF I created below as a Hard Copy of the way the Command Line *yt-dlp* Features Work and the How-To that will Empower US all with the Simple Truth that indeed, Linux ...Bears a VERY Friendly Face!
Merry Christmas to GMT Members ...and to All Who Dwell at GMT Nation who should feel FREE to JOIN UP with The GMT Nation Community and be Welcome HERE ...any time you like!.
*Spoiler Alert*
Wanna Save an 8K YT Video?
