New rear shocks in and truck feels so much better
Reactions: High Voltage
Aarkon said:
Where did you run the wires for the signal? Do you think maybe it got pinched
Though the trailer hitch, inside a piece of loom behind the bumper to the passenger taillight, into the truck through the taillight rubber grommet. The power and video cables are about a foot long, no visible damage, although there was nothing moving that could damage them. Chalking it up to being a $30 camera I guess.
I didn't like the wide angle lens for my application. Being mounted in the trailer hitch, I never had a visual reference to the truck so the positioning of things off to the side was always skewed. :mad:
BlazingTrails said:
Washed her finally last night. Been waiting because of rainy weather!!
:undecided: What drop do you have on your TB again?
Your truck licks SICK Blazing, love it :thumbsup: Tinted the windows yesterday, hoping to get some other mods done this weekend!
I have to change the driver side upper control arm, could only get the passenger done since i broke a bolt. then wash off all the red paint from work. Finally pack everything up and load up the truck for the weekend at jamboree with friends.
BlazingTrails said:
3" front 4" rear. Once I removed the spare wheel and associated hardware the rear came back up 1"......trying to decide if I want to drop the back down lower....
Me likey, are those stock diameter tires. Don't think I could handle dropping mine that low though. Maybe a 2"/3" max, and keep some slightly taller tires. I don't fear speed bumps much, and think I would end up moving exhaust mods to a higher priority spot on my mod list if I went that low. :banghead:
They are stock diameter @ 265/40-22". I have no problems ever with scrubbing not even when turning or going over speed bumps.
Reactions: Blckshdw and BHAMER
Changed oil & replaced oil filter
Also need to do that myself.
:yes:
What oil & filter do you like to use?
Valvoline and Fram normally.. Ditching the Fram for an ACDelco since I found out that Fram is junk and Walmart has them cheaper than Fram.
I use Castrol GTX High Mileage & K&N Wrench off filters
Picked up my flywheel bolts and dropped the motor in! Can't wait til tomorrow so I can finish(no garage :( ) installing it. Will post pics when finished'
:iagree:
Driving it to work
Sensurround
