PProph
- Joined
- Dec 7, 2011
- Posts
- 220
'03 TB LTZ
318xxx km
Heyo, more fantastical power steering issues. Hadn't done much to address the leak I referenced in this thread:
gmtnation.com
TL : DR, replaced all my PS lines in spring 2020, but screwed up one of the connections at the rack trying to get the cup seal out (protip, it was already out and I'm an idiot.) Used Edelmann lines. Now to my current issue.
Just been topping up the PS fluid when it goes low, and getting around that way since my screwup. Well, earlier this month it was cold one morning, we made a trip to the other end of the city, went in a store, and when I came out and started it back up, a connection on the rack to cooler return line came apart. Limped it home (yeah, probably not a great idea), parked it. It had come apart at a connection, shitty clamp. Replaced that spot with a gear clamp and I was up and running again. Fast forward to Christmas Eve, had since been driving it fine, even up to the city the night before when it was -30, no issues. Did some running around before planning to head out to my family's. Stopped and got gas, started it up, there goes another connection. Limped it home again, this time it was the next connector on the same line. Replaced with another gear clamp. Drove fine on Christmas night. Fast forward to Boxing Day (our Christmas supper was delayed due to weather), drove it around the block to make sure it was good. It was fine. Shut it off. Packed up. Started it up again, no power steering AGAIN. Have had it parked since, haven't checked. Not sure if I wasn't able to tighten that second clamp enough or if it's another connection down the line. The clamps on those Edelmann return lines are pure garbage.
So, at this point, I'm just wondering what I should do. As to my previous issue, I probably need to replace the rack anyways. To the current issue, I wouldn't be surprised if I've contaminated the system at some point causing a blockage and pressure buildup somewhere. I suppose I could also have a failed cooler (I see I could test that by bypassing which I might try). Or else I could have a failed pump. I've run it low several times over the last year and a half, so that's a real possibility. Part of me is really considering just doing an entire power steering replacement, the rack, the pump, the cooler, and at least the one return line, if not all. I think the Edelmann pressure line is good, but those clamps on the return lines are just trash.
Anyone have any suggestions on how I should proceed? Should I try to isolate and replace one thing at a time? I just figure if I put new everything in, I know the system won't get messed up by something else that's not been replaced, if you know what I mean. It's not a small bill, but we're also looking at a newer (to us) vehicle and the market is BRUTAL right now, so extending the TB's life would quite likely save us quite a bit down the line with the hope that the used market gets better.
*Edit, also saw the idea of using ATF instead of PS fluid for lower viscosity. Won't help my leak problem but might help my pressure problem? Is this something I should try also for the short term?
As usual, any advice is much appreciated!
318xxx km
Power steering leak at rack connection
Hey everyone, it's been a long time. I was sidelined for a while due to a chronic pain condition, and as such I took my '03 TB off the road at the time. Been driving some more lately, and looking to get the ol' girl up and motoring again. There's a few issues, but for the most part she runs much...
